Lol it is a different lookAlot better looking then my 4 bolt housing which is the same old look.
SignUp Now!Lol it is a different lookAlot better looking then my 4 bolt housing which is the same old look.
What intake are you going to use? With any 4" inlet (from the turbo) from my experience I had to run a 1" intake spacer in order for my air intake pipe to clear under my intercooler pipe. just a little food for thought.
Thanks man. Nick Micale is doing it .just waiting for the heads to get back from the cnc porting. Block is done thoughWould love to see your TA assembled? Who's building your block ?
Everything you are doing looks great , will be following.
Thanks man. Nick Micale is doing it .just waiting for the heads to get back from the cnc porting. Block is done though![]()
this was my old setup a 109 stroker with champion intake 6466 turbo with 4 inlet RJC Inlet pipe I had plenty of room underneath but you never know with this new combo lol![]()
Maybe I like the way it looks Chris .and like I said I had plenty of room underneath the intercooler pipe running the 6466 with a 4 inch inlet pipeDitch the vacuum block on top of the dog house, use a 1" plenum spacer with the vacuum lines tapped into it. Like ttypewhite said, it gives you more room (especially if you're using a distributor) and it looks a lot cleaner.
Not a bad idea though about tapped into the spacer if I do have to run a spacer .Ditch the vacuum block on top of the dog house, use a 1" plenum spacer with the vacuum lines tapped into it. Like ttypewhite said, it gives you more room (especially if you're using a distributor) and it looks a lot cleaner.
Never got to see those pic's , any chances you can share again ?I'm sure the photos I took in November were one or both of your guys blocks.
Boy your right I'm going to have to use a spacer this turbo sets a lot higher then the 6466 !!What intake are you going to use? With any 4" inlet (from the turbo) from my experience I had to run a 1" intake spacer in order for my air intake pipe to clear under my intercooler pipe. just a little food for thought.
Billet solid rollerWhat style of camshaft are you using? Billet or casting?
Ok sounds like a plan. Does anyone sale a block of plate for the top of the Throttlebody?If you need a spacer, your going to have to get rid of the vacuum block on top of the throttle body. It will definitely hit the hood. Your new vacuum source should either be drilled into your 1" spacer, or the back of the intake. A 1/2" spacer still won't clear..... Also, if you have a decent hoodliner, it's gonna be compromised by this latest edition........ask me how I know. lol
