TTA976
- Jun 22, 2014
Cant think about like that. Turbos have what is called a compressor map. At your boost level the 68 compressor is no where near where it needs to be for it to be efficient at 22#.
You have remember the T66 is a (6665) with a .63 exhaust housing which is a true stock style exhaust housing. You are making a HUGE change.
Also, a 6870 does not belong in a buick 3 bolt housing. That doesn't make any sense to me. That turbo is capable of 1100+ HP which could never be made in the 3 bolt Buick housing you are receiving.
There should be a particular match between a compressor wheel and A/R housing. That set up is no where near a close match.
Your car is barely going to be able to build any boost at the line if any. It's gonna spool like it's tied to a tree.
