The rear out of the camaro will fit if you have a torch and a bunch of parts to weld it in. Sorry but they're not EVEN close to the same. The G body metric chasis never had discs from the factory so you must either get a kit from an aftermarket source or cut the backing plate mounting up to use the camaro/blazer disc set up.
Since you're new here I'm gonna make some simple sugestions to you.
1) Go to your user controls and add some info on you and the car.
2) Do a LOT of reading before you do anything as far as mods. These cars can be cranky at best so if you don't know what you're doing ask first to see if someone near you can help. We like to help each other so it's not a problem
3) Keep reading and searching the board to see if you can find what you're looking for first before asking questions. Someone somewhere has probibly asked/done it before but once in a while it doesn't come up.
Not being mean or anything but I've been there myself and if someone had pointed some of these things out to me I would've been faster at learnig some of this stuff.
Welcome aboard.:biggrin:
PS: All of the turbo cars from 84 to 87 came with the 8.5" rear. If you don't have it now someone changed it out.
