SignUp Now!Says HPS in the sig. Probably the latest design of the GTS. Wouldnt make sense to run a GTQ/HPQ in a 4 bolt config unless you wnated to give off power at high rpm/boost.Is that a gtq or gts trim? what a/r? Nice job indeed.
What size stall is needed for a turbo like that?
Those coolant lines look great. Care to share the shopping list for that setup?
I got the 3.5" DP from Turbo Regal custom parts.
Did u modify it?
The a/r is 81. I believe, I got the 3.5" DP from Turbo Regal custom parts. If you look on my Cardomain site I have a pic of the part # sticker on the turbo and it says HPS
We had to cut the end that connects to the turbo just a lil bit for cleareance(I think because the turbo is so big), and we added the pipe that connects the dp to the wastegate.
Well it came out pretty nice. Did you buy that with the provided WG or without? I was interested in one of those DP for now but have no interest in that particular WG. Were u able to purchase w/out the supplied WG?
