I recently acquired a 1978 Regal with the 2 bbl turbo setup. For the money ($1000) I couldn't pass it up. I originally wasn't sure of the shape and was going to use this as a parts car. To my surprise, low miles elderly owned and mostly everything intact. The interior needed cleaned up a bit. I painted and/or dyed all of the faded plastic trim and replaced the steering column (due to a defective ignition/column lock mechanism.)
Anyways, I knew with this low of miles (52,255) that there were going to be some gasket issues.
Eventually I am going to replace the intake and heads/exhaust manifolds and turbo with ones from a 1979 and keep the 2bbl setup since it is pretty rare (even the TvBV, the PEVR equivalent for 2 bbls, is intact and in good shape).
The issue at hand, seems to be at highway speeds (45 mph and up) a significant amount of blue smoke. There appears to be an oil leak near the EGR valve. As I said before, I want to do essentially a head gasket replacement only putting on 79 hardware as replacements for the low flow 78 hardware. Aside from bad gaskets (due to age not mileage deterioration) is there anything else I should look for during the teardown?
