Engine info
Well I finally got around to taking the engine partially down today. It does have 2 dot rods and it is the correct block at least. As far as the rest I'm not sure what I can use. The block was bored .060 over and it has a standard cast crank turned .010, 0.010. I was hoping that it would have the correct crank but so much for that. I have 2 rolled filet cranks right now so at least I can have the correct one in it. The pistons are cast and sit .1025 in the hole so they need to go away. With the head gasket thickness that was on the head that would mean the total would've been .1475 in the hole and that's WAY to much for safety. Have any of you guys run a .060 block with forged pistons before?
The also used some sort of nasty sticky goo as a sealant for the head bolts and timing cover. It's all over the front of the block so I guess I'll be vating it to get the stuff off. It does seem to have an actual GM timing cover which is a good thing so I'll be doing Earls timing cover mods for better control of the oil as well as doing the block. They used the stock plastic cam bumper so I need a roller button and the rockers and pushrods are new which is a plus. That's about all I can tink of right now so if you guys have any sugestions I'm open. I may just have to do the 4.1 engine after all.
