84 - 85 parts for sale
keith theriot
Turbocajun
these are parts that were on my working engine before i converted to the 87 setup. If the item doesn't have a price make an offer and i will consider it. all items + shipping
85 to 87 coil / module conversion hot wire kit --$40
85 to 87 coil / module conversion plate--$15
85 accessory backet , modified for 87 intake setup.
85 Air duct to throttle body
85 clutch fan
85 fan shrouds
85 down pipe
85 engine wire harness , tps and IAC wires were extended for 87 intake setup. $200
85 fuel rail
85 injector wire harness
85 hard fuel lines to fuel rail
85 intake , ported but not gutted. $220
85 160 degree new thermostat
85 turbo oil feed line
85 2 - passenger side manifolds , they have been welded
85 positive battery cable
85 power steering pump
85 v- belt pulleys
85 ported throttle body
85 TPS sensor $20
85 trans dip stick
85 turbo bracket
85 turbo drain line
85 up-pipe
85 plastic vacuum pod $10
85 billet vacuum pod $20
85 A/C compressor , purchased in sept. 2011
buick g-body control arms
85 crank sensor
TPS booster
87 dog house modified for 87 intake on hot air setup
87 intercooler
87 intercooler fan 85 to 87 coil pack swap converter hot wire kit.jpg85 coil pack bracket.JPG85 accessory bracket.jpg85 air duct to throttle body.jpg85 alternator 120 amp.jpg
more pics
more 1
more 2
more 3
more 4
more 5
How much for the 87 dog house and 87 intercooler?
Do you have the brackets for the intercooler?
justa_v6 , $25 for the doghouse and $65 for the intercooler with shroud and brackets. the intercooler is a part the i purchased from someone else and never used it .
compressor -$65 + ship . I have two compressors my old one the clutch was making a lil noise so i replaced the compressor also, i think that it only needs a clutch.
Keith, so that is $65 for the one that is new without the clutch problem? How much shipping to 41017? Thanks.
Interested.
PM send. . . uhhhh wait. PM is down.
I will need to wait to send PM.
