84-86 Electronic Touch Climate Control Solenoids.
Turbo1dr
9 Sec Wanna-Be
I'm looking for the 5 solenoids w/hsg that mounts directly behind the glove box door.
I may have that. Let me look tonight and I will let ya know!
jpratt said:
I bought one from Brian Weaver last year. Very expensive, I think I paid around 400. www.gbodyparts.com
Was that for the complete AC Touch Control System?
I figured with all the cut out the AC systems someone has one just waiting to be thrown away... :biggrin:
Thanks!
Nope just the solenoid box behind the glovebox. Programmer is what they call it I think.
The control box is the most prone to going bad & is the most expensive part of the system.You may want like I suggested to Jeff was trying to get the coils re-wound.They do burn up.
The solenoids I have are tested and are working fine. It's the resistors I think that's causing the problems. I don't know what they are suppose to read on the OHM meter as a "good reading" for each of them.
WSLN 6,
Got your PM. I'll let you know.
I think i have the part that you need if wilson doesnt have it.
I also have the complete dash with that touchpad assy.
BW
Quick6'n'-K.C.,
Yep, that's what I needed. WSLN 6 and I made a deal. I'll keep you in mind should I need anything else.
Alright Sean Freisen i hope all your children are born naked :eek:
BW :biggrin:
