what is the differences between a stock 85 3.8 turbo engine and a 87 3.8 turbo engine both from a GN . other than the obvious hot air setup.
I noticed the casting number difference from a 440 (85) and a 109 (87) block
My main question is for a build up . just wondering if the block and heads crank rods and pistons were worth it if i use the 85 block . thanks for all info ahead of time.
