It's possible the car is not making enough power to use up the amount of fuel programmed into the chip. I would first look at the WOT fuel adjustment to make sure it's at 128 (the default). If it is, then try reducing it 3-4 numbers at a time, to see if the bog clears up.
Regards,
Eric
Eric,
That helped out ALOT!! I dropped the fuel down. Bog is gone with out Alky. Big help. Thank you!!! now I will get the boost adjusted and try and tune it in. Thanks for your help. And it is very easy to do great directions with the chip!
Jim
