Car has a miss at idle and really gets bad when you put car in drive and it running rich. Is there some way to ck injectors without taking turbo off? Car has lt1 maf, translator, 40 psi injectors, tt chip,87 computer,mat harness and sensor was installed car has a turbomotion intercooler setup like in the pic below.
scanmaster readings are
Af 05
L8 36
Int 128
Bl 142
clt 175
ats 82
Rpm 775
Tps .38
Iac 48
Cc 00 cross count number never moves from zero at idle
02 328-339 these numbers dont change much always in the 300 range at idle
the miss i think is an injector but they are so hard to get to.
Af 05
L8 36
Int 128
Bl 142
clt 175
ats 82
Rpm 775
Tps .38
Iac 48
			 My BLM's start out normal and when the car warms up after driving around, they fluctuate. Down to 119 while cruising and all the way up to 142 when in drive at a stop light. Is it my O2 sensor?? What else would cause this??
