Ok I am new here and have been doing nothing but reading since I bought this car several months ago. I have a problems I can't figure out
so I hope you guys can help,
1st, at idle I am seeing 60# on my oil pressure gauge. First thing I thought of was the oil pressure relief valve, but that looks to be fine in fact the spring and valve slide right out. The engine has about 5,000 on a rebuild. I'm stumped and about to replace the oil pump, I have the poston oil filter mod on the way so should it need to be replaced that will be the time. I am hoping someone might have run into this before and have some ideas, I have read these cars are notorious for oil pressure problems. BTW the drivers side valve cover is vented. I also believe the oil pan has been replaced by a deeper one.
