Having an issue with my 86 GN - Equipped with kill switch and viper alarm system installed by original owner in 1991. (Might be relevant) Battery in great shape (Optima battery) When car is hot and has not had a chance to cool down (at least an hour) won't crank. Installed a direct line to starter as emergency start until this is resolved. Starts right away using that direct line. So it's not the battery and not the starter. My mechanic suspects a possible failed (or failing) relay used by one of the two security systems even though they are under dash and not exposed to engine heat. And so we will be trying to track this down but wondering if anyone has experience with this problem. It might save us some diagnostic time if someone else has same experience and a solution.
Tom
Tom
