Here are some more pics of the engine. I've been tight on cash the last little while so I took to opportunity to do some underhood detailing and cleaning. I wasn't happy with the cluttered look of the wiring, so I cleaned some of it up a bit and moved some relays and the MAP and ESC module down inside the passenger fender. I replaced the powersteering reservoir (from a ford taurus) with one from a chevy safari with hydrasteer. the mounting is better and I moved it to infront of the rad. really cleans up engine bay. Some specs on my build:
3.8L bored 30 over
214/214 comps cam
CPTE60 turbonetics turbo :biggrin:
42# injectors (not installed yet)
turbo feed/ oil filter relocation kit
performance chip (turbo tweak, If I remember right
stock location intercooler... FMIC in the near future
Edelbrock high flow fuel pump
RJC billet aluminum pullys and AC delete bracket (anyone know what belt to use?
700R4 trans with a trans adaptor plate
Polyurethane suspension bushings
29"/9.5" Hoosier slicks... (too big?)
I plan on replacing that UGLY upper rad hose with a stainless or aluminum tubing piece, and eventually would like to step up to a larger throttle body/plenum and the RJC power plate. The champion racing fuel rails get me all excited, so those might be something to save up for... just like the looks of them.
Any suggestions on my set up would be welcome.. this is my first engine build ever and I want it done right.
