86 Buick T-Type Stage II car with 64,000 miles on it.The car is silver.The car has Electronic Climate Control,Power Everything,Astro Roof.Car is clean. It has Fast EFI Sequential system. RJC A/C delete, Delta Wastegate, Innovative Boost control, Fuel pressure gauge on hood, Big Mouth cold air induction system 4", 3.5" single exhaust, roll cage swing outs passenger and drivers side, New M/T two piece wheels front and rear with new M/T Drag Radials. Has 15 runs at the track and 150 miles of street driving on fresh motor
Stage II off center block
Carillo Rods
Weisco pistons cut for StageII Heads
Block and heads are O-ringed
3.625 Forged Steel Crank
BHJ Balancer
The Wheal Flywheel
Champion Heads
Comp Solid Roller cam
Scorpion Roller rockers
Champion Ported Intake with 83# injectors
76 Q-trim Turbo.5
Houston Headers and 3 1/2" down pipe and exhaust
U-1 front Mount Intercooler
TH400 w/transbrake & ultrabell
10" Hughes 3600 stall convertor
3 1/2" Aluminum Driveshaft
10 bolt rear end 33 spline axles w/spool housing has extra bracing on axle tubes
Aerospace front brakes
Poly Bushings
Koni Shocks
Wolfe rear sway bar
Car is Mini tubbed
8pt Moly Cage
Dry cell Battery mounted in trunk
New Autometer gauges
Promatic shifter in Console
Line lock
Aluminum Radiator
Twin XP pumps mounted in tank
Russell fuel Injection lines
Car has run 10.01 at 134mph on 21 lbs boost with safe tune. 10 lbs boost on launch. Extra Parts included:
BGC manifold with Fuel Rails used few hundred miles.
Stage 2 Off center intake and fuel rails,BMS 4 bbl intake converted to FI by Champion icluded are fuel rails and brackets, Lingenfelter 90 degree plenum and dual 57 MM t/b and 4 inch adapter to fit intercooler pipe.
New Chrome mezure water pump, still boxed
New Tiano Laptop holder and Compaq Laptop computer.
New Accufab polished 70 MM t/b
Have many pictures I can send.
$27500.00 Duane 206-849-0984
Carillo Rods
BHJ Balancer
The Wheal Flywheel
Champion Heads
76 Q-trim Turbo.5
Poly Bushings
Koni Shocks
Wolfe rear sway bar
Car is Mini tubbed
8pt Moly Cage
Line lock
Aluminum Radiator
