SignUp Now!What intercooler would you guys use? Still haven't decided on that
The lightest best fitting one that will cover the mass flow potential of the combo.What intercooler would you guys use? Still haven't decided on that
I considered the 8374 but the 9180 will be happier on this combo. Should be 60lbs/min on the low setting. Most hits from 4000+rpm. Cam was ground with a tighter LS than I would use for drag racing to increase ex pressure at lower rpm and really get the rotating group moving. Power should be very strong from 4500-6000@ 2:1 pressure ratio. Gearing plays a large role. The compressor maps are nice and wide on these efr turbos.TurboDave, we are using the integrated BOV port that comes on the turbo, the turbosmart fits into the factory location.
Brian, we looked over BW's matchbot extensively to pick out this model. Our wheel numbers will be just shy (at 18-22psi) of what you want but response should be phenominal. It's a street car(stock block as well) that I may put on the track every now and again so driveability was a big concern. Of course, with race gas or alky and 30-40psi it will run with the best of them. The 9180 should breathe easy at 500 and still really respond well. Looking forward to seeing how your project turns out as well. Keep us posted.
Have ya'll talked/PM'd GNX405 on this board? He's a Borg Warner turbo design engineer and may have some insight for you!
Been in contact for a long time. I plan on testing a 9180 on a v6 next year. As much data as possible. Hot boost, cold boost, hot boost temp, cold boost temp, shaft speed, exhaust pressure, etc. I plan on running to the end of the compressor map. Engine is a 9.3:1 stock stroke. Really good heads and solid cam. At 30-32psi it should run all in depending on air quality. 95lbs/minHave ya'll talked/PM'd GNX405 on this board? He's a Borg Warner turbo design engineer and may have some insight for you!
BPE2013@hotmail.com
I have not spoken directly to John, but I am pretty sure he is aware of the project! It is great to have a Buick contact within BorgWarner for sure
I am aware of the project and am eager to see it succeed. Which turbine housing are you going with?
Here's a link to a build thread of my Mazda RX-7 with a GN engine boosted with an EFR 8374.
Holy EFR Batman!
It's not a Buick, but it's a Buick at heart, the thread shows that an 8374, and therefore a 9180 which has the same pierce points, will fit on a Turbo-V6.
Ha! Seth sent me a few pics of your car as it was coming together! Very nice sir
