87 GN SE Va.
Steve V
Steve V's Automotive 757 560 2782
This a nice driver,not a garage queen.
87 GN 124,xxxk fresh motor 5-10.
.030 Hyper pistons,.020/.020 crank
ARP studs,fel-pro gaskets
TA performance cam bearings
wide rod bearings
bueprinted oil pump
TA49 turbo with garrett housing
Dutt neck IC
30 lb injectors,TT chip(2006)
Gbody downpipe,aftermarket exhaust(older hooker system?or dynomax)
3.42 posi
has new bodyfillers front and rear. new weatherstrips door and roof rail(aftermarket). 2-09
Interior is an 8,it's clean and in good shape. Headliner is faded with some spots. Small rip in drivers seat cover. Steering wheel is showing it's age.
body is a 7,decent paint,shines would need repaint to be perfect,nice for a driver. Small rust spot in corner of driver door. No rust in floor pan,quarters,rockers. Wet sand and buff would help a lot,has orange feel,a nice 20 footer.
Engine bay,trunk are detailed,floor pan was cleaned,painted nice carpet installed.
Cold AC with 134a retro,new accumulator,orfice tube,good compressor.
New upper and lower balljoints
new upper control arm bushings
new fbody radaitor
trans cooler
new belts and all hoses
new alt
new crank sensor
new cam sensor
aftermarket guages
will need front tires soon.
current VA inspection
Rebuilt trans 11/2009
ck shift kit
10 vein pump
wide band
correct BRF valvebody,governor
BRF servo
New clutches,steels,bushings,thrust washers
trans is solid mid 11sec capable.
Correct D5 convertor
No flares,no leaks
new 340 pump
hotwire kit
powerplate
Price is $10,500 cash only. No trades
cell 757 560 2782
email sasybit@ymail.com
http://www.turbobuick.com/forums/virginia-area/318884-1st-build-new-place.html
http://www.turbobuick.com/forums/virginia-area/282268-weekends-project.html
http://www.turbobuick.com/forums/virginia-area/242899-my-latest-project.html
this are some of the projects I've done to it since 12-08.
I now have 6 cars so this one needs a new home.
more pics..
and more.
last for tonite...and the pics make the paint look better than it is IMO..
also let me add that the drivers side header flange is warped and it leaks at start up until it warms up then goes away,BLMs stay 125-132 so it's not affecting fuel trim much.
Rear end has a wine between 45-55mph,I believe it's the pinion bearings,carrier bearings are tight,posi works,fluid is fresh with additive.
Few items I left off..
There is a crack in the windsheild behind the review mirror,not in drivers line of sight.
Also the windows are sloooooow,esp the pass side. Could use some new motors and a good lube job.
I am more motivated than before to sell,so if you want to make an offer the worst I can say is no.:wink:
Oh noooo!:( Looks great! Is it making good power?
Yup running very well,love the smell of paint curring everytime the engine gets to temp:biggrin:
Have you ever ran this car at the track? Has it been on the dyno? If fit is still around in Late September i'll have to come and look at it.
One time with stock turbo IC, 13.10 . It has not been on the dyno and there aren't any plans to do it in the future. Low 13 high 12 sec car. Will need bigger injectors/new chip to go faster or octane/alky. I am not gonna be beating on it or driving it a whole bunch.
What cam do you have in it?
It's a stock replacement cam I bought here on this board in the forsale section. These don't respond to cams like small blocks because they are force fed. Stock cam has been in the 10's.
Undercar pics..
engine is now entirely black(freeze plugs,front cover,bolt heads) and stock DP has been replaced with gbody DP.
few more
OK, Steve. I missed out on the last one because I kept getting deployed. Let me ask my wife if I can buy this one... Ben
Ben ask away got your PM call me..:)
To other interested parties,when I get a PM asking me for engine specs,whats wrong with car and pics....I start to wonder....Everything is listed in the top of this thread. Links to the entire life of this GN during the 3 years I've had it. Scroll back up and enjoy.:)
So Steve does cash talk?
Cash does talk,but it's gonna be in the right quantity. As stated above I am open to offers all I can say is no.
This car is documented pretty well in this thread and I have described it to a T. No surprises.....
And speaking of cash,that's all I will accept,no MO's,checks,cashiers checks,CASH only.:)
