87 Buick Limited with 71848 miles and leather seats
Fresh rebuilt .30 over, Gridle block
210-215 roller cam with Morel lifters, stock rocker arms
Ported heads with EGR sealed
TE-44 (no play in shaft)
009 inj.
Huge 28 row SLIC I think it is a precsion
Red stripe converter (2800 stall)
New 2 1\2" exhaust with magnaflow mufflers
Like new M\T 275\60\15 drag radial
Front tires have lots of tread but Drivers sidewall is cracking
When my dad bought the car it had been sitting for 5 years we started the motor which had a rod knock ,but with the deal we got a fresh rebuilt girdled short block which is in there now, so have possibly the original block which is .40 over but bad crank.
Car had some minimal rust at bottom of doors which I scraped loose and sprayed some rust killer and repainted , the rest of the car is rust free to my knowledge
The lower front pass fender has slight dent, but the car is very straight
The leather seats look good except drivers upper back section has small 1" cut that I believe could be repaired easily,other than that no wear, rips or tears
The paint is shiny ,but not really a good job,but looks decent from 15 foot
Car doors shut good and car drives good, the transmisson shifts firm, I have only drove it around neighbor hood due to not tagged or insp so motor only has about 5 miles on motor
I recently flushed all brake fluid and bleed brakes.
The A\C does not work, everything is there, have not had time to figure out and dad does not want to put any more money in it.
Asking $9500 cell 713-412-2780 Tim
009 inj.
