Troll allert aka "87gninpa" aka Shawn Walinsky
I would like to bring your attention to a troll among us aka "87gninpa" aka Shawn Walinsky.
On May 23 2004 I won this coil pack on ebay
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2479934012&sspagename=STRK:MEAFB:IT
I sent Shawn the money and he sent me the coil pack and module. He advertised it as a 86/87 GN coil pack and module. When I got the coil pack in and tried to plug it in it would not match the coil pack plug. I informed Shawn that it would not plug in. After further investigating I noticed that this was a different coil cap then the 86/87 GN. I sent Shawn pictures about the differences. He said he would look for it. Then he asked me again what I was looking for.
Needless to say it is not July 9 2004 and he has stopped responding to my mail. Maybe this ill get his attention. I have also left negative feedback on Ebay...
See the emails below with his responses. He has not responded since June 26......
Thanks,
Ernest
Shawn,
I have an 86 GN and this module I got from you does not plug into my harness. My plug is a 14 pin connector but does not plug in. Any idea why? Is your GN an 86/87?
Ernest
-----Original Message-----
Sent: Wednesday, June 16, 2004 11:22 PM
To: eqs@frontiernet.net
Subject: Re: eBay Item Won! BUICK GRAND NATIONAL INGITION MODULE COILPACK GM, ETC (It...
Yes, it is form gm, it worked fine on my GN, had it one there for about 3 months this winter. Only reason i took it off is because i switched to the type II ignition setup
Yeah the plug does not match the module although it has the 14 pins but I suspect this ignition module is for a different car.
There are quite a few mid 80's cars with ignition and coil pack set up and they are not the same. They will have the 14 pin setup but the plastic plug is set differently.
Some have 14 pins but the plug only uses 13. Know what I mean?
Before you send another send me a picture of the module. The stock GN module is thicker in height then this one.
Thanks,
Ernest
Sent: Sunday, June 20, 2004 11:27 AM
yea it definately worked when i tested it in my car. ill see if i can find another one around here that i can send you. are you sure it doesnt fit? thats kind of wierd
ill get back to you
Shawn,
Please let me know if you find the correct ignition module. Thanks, Ernest
Sent: Sunday, June 20, 2004 2:55 PM
Ok i will, i think that was the module i had for a hotair car. Let me find the other one and ill send you a picture
Shawn,
The hot air module looks like this.
<http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=7905599512&ssPageName=STRK:MEWA:IT>
Please get back to me about either me returning the module and getting the money back or you sending me the correct one and I will return this module.
Thanks,
Ernest
No. I need one for a 86/87 GN.
Sent: Saturday, June 26, 2004 1:05 AM
You need one for a hot air car??
Shawn,
Which GN do you have 86/87 or 84/85?
Mine is an 86 GN.
I have included pics of my module and your module you sent.
Picture left_86_CoilPack_right_your_coilpack.JPG has my coil pack on the left and yours on the right. Notice the difference where the connector would go. Also the hole for the screw id bigger on my then yours. Notice the module under the coil pack the the one on the left is thicker and has shorter studs. The one on the right (yours) is thinner and longer studs.
Picture 86_coilpack_module.JPG notice the module connector plug.
Picture your_coilpack_module.JPG notice the module connector plug.
The slots above and below the pins are different on the modules because they accept different connector plugs.
I need the module that is exactly as my coil pack module or it will not bolt up.
Does this make sense now?
Ernest
Sent: Saturday, June 26, 2004 5:58 PM
Before i send you another one, what exactly is the problem with it>??? it bolted up fine to my GN when i had it on there. Is it the actual pins or is it the screw?? because if its the screw then you can just get another one for your connector. If its the pins, ill send you another one. Its just wierd because that one worked on my GN.
Thanks,
Ernest
Shawn,
Ernest
Thanks,
Ernest
ill get back to you
Shawn,
Shawn,
Thanks,
Ernest
Shawn,
Mine is an 86 GN.
Ernest
