How do you ID a 9" Ford housing end for the proper bearing size and brake backing plate?
I have a pre 69' 9" that I had narrowed about 15 years ago and need to get it going again for axles and brakes. I haven't pulled the section out yet but can you tell me if it's that old would it be a 31 spline vs. a 28? Aren't all Detroit lockers 31 spline? I have a D. Locker to install as well.
Another thing. The only Nodular housings I've ever seen had the "N" cast into them. This gent tells me that mine is a Nodular because it has the rib (one only) cast into the front.
TIA,
Roger
TIA,
Roger
