92 Yukon trans prob
larry33kc
I have a 92 yukon 350 700r4 4x4. The trans is revving really high before it wants to shift it doesnt seem to be slipping just not slipping. I need some ideas to fix this thing.
Check the TV cable at the throttle body. If it comes unhooked or breaks, it forces max line pressure causing late or no upshifts.
If that's all in order it could be many things, most of which will require a rebuild :( Stuck pump slide is one possibility. Long story short, if it has to come out of the vehicle a rebuild is pretty much required, partial rebuilds are a crapshoot.
Have u ever been in the trans? Are you the only owner? How many miles? Have you ever serviced the trans? Give as much info as possible and someone can give an educated guess. HTH.
Check gov pressure at the tap and make sure it's not stuck. It may have debri and the valves for the gov is hanging, whitch will not let it shift and not slip either. Good luck
