SubZero350
To boost or not to boost
- May 26, 2001
Anyone find the parameter for VSS calibration in the $5b system for 94-95 supercharged 3800 GM computers? Also could use information on the location of the DTC code enable for TCC Slip code. Having trouble w/ 3800 SC and 4T60-E w/ 3.33 final dirve. Keep getting a DTC for TCC Slip and then I loose TCC and 4th gear op until I clear the code again. Put in a 3.08 final drive unit and no codes after 4 months. Want to run the 3.33 unit for obvious reasons.
