TurboDiverArt
The Guru Thorn
- Nov 8, 2002
For Sale:
Set of 6 Delphi 95# injectors. Cleaned and flowed 100 runs ago, 3 years. Perfect running condition. I upgraded to 160’s to run TSO. $300 shipped
ARP long stock threaded press-in wheel studs, chrome open-ended lugs and washers. Complete set of ten for fronts. Like new, 30 runs/half season. You can use stock style lug nuts when running stock rims if needed. I upgraded to Aerospace brakes mid-season 2006. You need longer studs, visible through open-ended lugs to be legal when using aftermarket aluminum wheels. I used these on Weld Racing wheels. These will cost you over $75 to buy new, $50 shipped.
Stainless steel braided front brake lines. Stock configuration, direct replacement for your stock rubber lines, uses all stock hardware. Perfect condition. Upgraded to Aerospace brakes mid-season 2006 so no longer needed. $50 shipped.
Email: Artpaltz@optonline.net
Thanks,
Art.
Thanks,
Art.
