a/c compressor nut and bolt ?
nuc
Could someone tell me how many attachement points are there to hold on the a/c compressor. I have a feeling that I am missing a nut and bolt that goes through the bottom of the compressor into the bracket.
I have one nut even with the clutch and engine block and I have a long bolt and nut even with the clutch and the drivers side of the car. Sould there be 3 attachment points? If so, can someone tell me how long and what size the bolt that goes through the bottom of the compressor should be?
There is a 14 or 15 mm size head long bolt threading into the compressor from the bottom motor side of the bracket. It is below the AC switch facing toward the firewall. Hope that helps.
Mitch
