Finally (after a year) getting back to working on my WE4. Before i put it away i was having a problem with it buring oil and smoking at idle. I have a rebuilt engine and new turbo but its still doing it. Did a compression test and everything seems good. Still have not done a leak down test. My question is i have a fram pcv valve in there now could this be causing my smokeing problems? Does the A/C delco pcv make that much of a difference? What are some other things i can check to cure this problem?
