My A/C recently stopped working, I noticed last year before putting the car away the compressor would cycle very fast, on off, barely cool the car. Car has just over 53,000 miles. I don't use the A/C lots but I want it to work when needed.
Since I will be replacing the heater core with a new old stock GM unit, should I go ahead and replace the evaporator while I'm in there?
Should I get a new accumulator too, I'll be going with a Blue orifice tube and 134A refrigerant or equivalent.
Do you guys think the A/C lines are OK to use with R-134 or similar Duracool coolant. Are there after market lines available for use with R134?
I'll be evacuating the system and seeing if it holds vacuum before I proceed but just wondering which of the above mentioned parts to change and where to get them?
Any suggestions would be greatly appreciated.
Jim
Jim
