Hi - I am using a GEN 7 DFI on a 1989 Turbo Trans Am that I bought 4 months ago. The air conditioning does not work. The previous owner never cared about air conditioning so it's not clear to me whether it was ever hooked up. From what I understand, the ECM is supposed to turn on fan #1, add some idle speed and activate the compressor clutch in response to an air conditioning request.
The A/C clutch is not engaging, there is no idle speed change and fan #1 is not turning on when the A/C is turned on. The passenger compartment blower motor and ducts are working fine though.
A mechanic was able to manually jumper the AC clutch relay to make the compressor cycle on and off. So we know that the refridgerant system is mechanically OK. Since he was not familiar with the Accel GEN 7 system and had no documentation, he did not know how to get the ECM to control the A/C clutch and cooling fan. If we get the electronics and software figured out, the A/C will operate.
Please answer:
a. To engage the A/C clutch and turn on the fan, a signal from the HVAC control head would have to be sent to an input on the GEN 7 ECM. Which input signal wire or harness wire would that be on the GEN 7 ECM? The STI?
b. Which GEN 7 ECM output wire should go to the A/C clutch relay to energize the clutch?
c. On the Output Configuration Screen, should the VTEC Control/AC Clutch Disable switch be set to "AC Clutch Disable" or "VTEC"?
d. On the Output Configuration Screen, should the "AC Request Input Turns Fan 1 On" switch be set to "On" or "Off"?
Thanks, Bob Crow
PS - Yes, there is a FAST Track GN/Accel wiring harness adapter on this car. But I want to make sure that that the basic Accel GEN 7 system is wired and working right - first.
Please answer:
Thanks, Bob Crow
