A few more questions....
DWB47
What size are the coolant lines to the TB. I am going to block them off, I pulled the hose off to match but left it at home. I was hoping to pick some hose/caps up on the way home tonight. Also should hook the inlet and outlet lines together to bypass the TB or should I just cap the 2 coolant lines. Thanks.
i just capped the two coolant lines where they come off the main lines by the intake manfold. i didn't buy any caps or anything- i just screwed some 5/16" allen head bolts in the hoses and put a clamp on them. if i ever drain the coolant, they will serve as convenient air bleeds when i fill it back up.
+1
