So should I continue with what I am doing? I am not to concerned with the hole in the quarter. My plan was to cut that rust out and just fiberglass it unless my friend has time to do a patch panel for me. Getting a patch off a car around here will be next to impossible beings for many years up until recent they salted roads, now I was told by a friend they use some sort of chemical that is non corrosive
. The crack I am sure is from body flex, as all for corners of the roof have them. I don't know what to do about the hole in the door jam. Can I get away with soldering it after I remove the rust? I know I make the car worse than what it is but my father thinks I should use this shell to keep the car as original as possible. The shell is the only body part aside from the trunk that will stay original. I also took aa pic of teh bottom of the passenger door. I cannot tell if it is salvagable or not beings about 5 inches of the lip of the skin is rusted off. Can I bead blast the door and reweld the bottom if there is enough metal? At this point I am considering doing a half assed frame off (don't plan on removing drivetrain, it took me forever to get it perfect as possible), is it worth doing this much work on these cars?
