A Q'S about the older SMC kit....
flowerpower
I installed it about a few weeks ago and got to drive it for the 1st time 2 days ago.....Here's the thing I took the line off going to the fuel vapor canister "the steel line under the TB and to the left of the fuel presser regulator......Will this get enuf presser?
Also the the bottom dial when I tun it down seen to keep turnning?....I tryed to turn it down becouse i only have it set about 13lbs......any ideas
Thanks guys..Eric
Need a little more info. What was your reason for unhooking the line??? Are you having problems that are causing you to turn down boost to only 13lbs.??? ..... I also have the older SMC kit and my knob will also continue to turn. I assume you have an aftermarket boost gauge you can watch to see when the alky is spraying. Put the knob between low and high and watch to see when it comes on. For me it's set to come on at 12lbs.
I got it about 2 years ago and I was wondering about the bottom dial turning and turning ..."but not stopping" but if what you say its ok I guess it not broke....I turned it down to see if it came on around 10psi and NO light... I know the pump id working "IE test button"
is thhe spot where I placed the biist line ok?......any help you guy can give would be huge help.....Eric
