Ok I have this on going issue with this friggin HV oil pump (should have just kept the factory gears). I had oil pressure before the engine was rebuilt in my car and installed the HV pump. I installed a HV oil pump into my car tried priming it at least 8 different times doing something different everytime. Yes the cam sensor is engaged, pulled the bottom cover off the pump and had someone bump the car over, the gear spins freely. Someone suggested main bearings (checking those tommorow morning), but I have oil coming out of my turbo oil feed tube, not squirting like it should, but it does flow out and increases with throttle. Also the engine sounds perfect, no noises, no anything, just no oil pressure. This leads me to believe its my oil pump not providing the proper pressure and catching a prime. I used both the gaskets that came with the kit, the yellow spring, cap, shimmed it per directions and packed the heck every friggin hole on the oil pump, still no oil pressure, it won't catch a prime for *#@%. Best I can do is get it to go to 5 psi with slight throttle, then it falls back to 0 and the oil light comes on. I even went as far as to ordering a new thrust plate, notta, still same results. Maybe switch back to GM gears and get rid of the HV gears, plate? I have read as far back as page 49 on oil pressure problems, although some sound like my symptons, the fix is Ok on mine. I now have extra set of HV gears, since I ordered a HV kit with the thrust plate. Melling better hope to god when I mic both sets of gears thier is minimal size difference between the two sets. My only thoughts of what could be wrong are, wrong gaskets with the kit, spacer plate wrong thickness, gears different heights? It seems to me not all HV pumps are created equal, its hit or miss with them from what I've read.
