AC Clutch not engaging 85 GN
Big Dawg
Hi everyone,
I had posted a post for some help In the General Tech section and only got responses from PACECARTA .... I ordered Shorter belts and the four seasons relay....Thank you.
I put as much info as I had in this link:
So I ordered the relay and that didn't help. I also ordered the correct R134 Pressure Switch and that didn't help.
I even got another ECM and swapped my Prom and TT chip and still no dice.
My old relay and the new relay just click away until I turn off the power at the Digital Climate box......does it when it's set to hi 65 heater option....no clicking on Auto at 65 hi.
I have scoured years of post in regards to this issue and still no luck. I have used my multimeter and followed the tech pages on GNTtype and the other forums. I have checked the power at the harnesses of the heater module (New from Kirbans)...there us 12volt present at the brown 5 pin Harness. There is the light blue wire from pin B8 that splits off into 2. I have jumped the pressure switch and nothing. When I jump the pink/black wire amd the green wire the clutch engages. I have pulled out the Digital Climate Control Unit and checked voltage at the 3 connectors and the different wires as per the instruction on the diagnosis writeups from the factory manual and everything seems to be in working order. I have checked all the Fuses under the dash and all are good...none are burnt out.
My big question is what triggers the B8 pin to energize and send 12v through the green wire to the Compressor Clutch.
Is there any other fuse or relay that I am missing somewhere? The 85 Ac Compresser only has 1 pigtail as ther eis no high pressure switch or factory electric fans. I replaced rhe pigtail wirh the green and black wire with a new one with diode...thinking that it was faulty.
The compressor is new and has been filled R134, the system has been tested and has full vaccum...no leKs anywhere.
Please if anyone has had a similar issue throughout there time with there car please send me any info.
Thanks Am
Question - did the air conditioning system work at one time since you owned the car ?
Hi HotAirWH1, yes the Ac was working til I swapped out my compressor last month. My Ac clutch was squealing when engaged so I replaced it. When it was all said and done and refrigerant back in the system it won't turn on now.
When switching over to 134a, was the orifice tube replaced & if so, was it installed in the proper direction?
Hi yes it was replaced and installed correctly, same direction as the old one was pointing. Also replaced the accumulator.
The Ac worked perfect for 2 years...even when the clutch was squeeling.
Do you get +12 on the purple wire shown in the diagram when A/C is selected properly to turn on the compressor?
It's right in the troubleshooting part of the diagram.
On the unit itself what setting turns on AC .........Auto - hi - 65??? Or Econ, Bi-Level or Heater??? I always just put it on Auto Hi 65 when it was working and it adjusted based on Cabin temp (in car sensor)
I am going back out to the garage to double check the Purple wire. On troubleshoot it says purple wire 6v On and 12v Off.
Is the purple wire on the back of the unit and the Purple wire that goes to the Heater Control Module (Upgraded Casper unit) the same wire???
Hi,
Just checked the purple wire at the brown 5 pin Harness and i get 11.17v when the controls are set on heater amd economy only at Hi and coldest.
When the controls are set to Bi Level and Auto at Hi and coldest the voltage reads 1.06v.
I also checked the pressure switch and when it is on Auto and Heat the green wire on pressure pigtail reads 11.07v.
When I switch the settings to Economy and Bilevel the green wire on pressure pigtail reads 2.72v
Looks like solid state switch A sends the signal out the light green wire, then to the press switch and relay cutout contact out to the compressor.
Do you have +12 on the brown/wht wire on the Blower and A/C clutch control module near the purple wire terminal C on that connector?
I will check In the morning. Thank you for your help.
I have a guy in our local turbo buick group that reached out saying he almost identical issue and it ended up being the actual head unit. He sent it to Caspers and they said they could repair so he bought one from them.
He offered for me to go by his place tmrw and plug his into my car and see if that changes anything.
I will check the brown wire first thing. It's getting cold here now.
Hi so after plugging in a working climate control unit...still nothing.
Is the fan control and fan working properly? When on A/C that is.
My car is a hot air 85. This c9mpresser doesn't have the hi pressure switch or the ac switch connectors. I have aftermarket electric fans installed that run off a seperate thermostat
Are you referring to the 5 pin connector under the hood near the heater control module? There is a brown wire (not brown and white) on the C connector of the 5pin there that has 12v when switched to auto Hi amd coldest setting.
I meant the blower fan the module controls, does it work properly even if the compressor does not engage does air come out the vents and can you change the speed of the fan?
yes everything works...all the vents work along with the speeds. I popped down glove compartment and can even here the motor working when I switch from cold to hot. Also the Bi-level works as well.
I am wondering what type of voltage is supplied to the 2combined light blue wires that goes to the relay. Is it a 12v signal or something else. I am just wondering as I was thinking out loud and thought what if a put a toggle switch of some sort to activate the AC Clutch manually. Use a grounded toggle and have 12v from the battery to the light blue on the relay. Only if it is a 12v that goes to that terminal on the relay.
Thanks for all your help
Ok back to square one for a second. When in A/C mode, set at 65 A/C which should engage the compressor, do you get +12 at the pressure switch itself on the light green wire? If so use a short jumper and jump out the two terminals on the switch removed from the accum/.drier.
That should send the +12 out to the relay light blue, so then check the light blue wire at the relay and report back. Read with a meter to a good ground.
It's hard to read what is working ok and what isn't at this point, they are quick tests however. Key ON tests A/C engaged via the controls.
The light blue wire from the pressure switch has to go back into the car and then back out to get to the A/C cutout relay so the signal could be interrupted by a bad connection if it's good at the pressure switch but not at the relay blue wire.
Okay so I put it on Economy Cold 65, it sends 12v to the green, jumped the switch pigtail and it only sends 2.6volts to the relay. Is the plug in that goes to the ac pressure switch bad.....should I just put new terminals and try that? See if 12volts goes to the blue wire on relay this way? Also when i run the green 12v to the one side of switch and put the meter on the other side it shows 12volts coming out of the ac pressure switch. It just doesn't get to the relay at 12volts...instead 2.6v. It should be getting to relay at 12volts correct?
