AC Compressor
87T-Type
My AC compressor is not engaging. I recently had everything apart up front due to some mounting issues. When I put everything back together I had an extra connector. Its not the 2 connectors used for testing. My question is, is there only the one connection on the back of the AC compressor? Thats the one I have hooked up, its red and round. Is there any other connections to the compressor itself? The extra connector is green and flat with 2 metal prongs. Interesting thing is it looks like there is a jumper in the back of it. I have no idea where this thing goes. If you need pictures, I will try to post them tonight. Any help is appreciated!
The flat connector goes to the compressor clutch coil. The pins that it plugs into are located on the cluth coil, just behind the pulley.
The jumper that you see is a diode.
Dude
:biggrin: Thank you so much! Its been driving me nuts! Not to mention so hot out I cant drive her with out the AC! Thanks again! This board ROCKS!!
