AC Condenser
jskarateka
Ordered a Cometic for the oil pan, haven't had good 'luck' with cork or Right Stuff. Looking for recommendations/experience. I've been hedging toward spraying the pan side with Permatex Copper Spray and leaving the block side dry (after cleaning both with brake cleaner).
Thanks guys.
I put it on dry. Hasn't leaked and it's been two years already.
I have used a bunch of these over the years, always install them dry and many times have had to pry the oil pan off after removing all the bolts.
put on dry.
engine in car ?
Use small wire ties in all four corners and start the rest then cut them off with a pair of side-cutters
