accumulator
VIN7
What does the 1-2 accumulator do? Also, how does it affect 1-2 shift characteristics?
Mike
the 1-2 accum's job is to
Act like a shock absorber during the 1-2 shift. Many things attribute to the 1-2 shift feel besides just the 1-2 accum.
the 1/2 accumulator provides a throttle sensitive derived pressure to control the rate of band apply pressure in the circuit.oil pressure ,spring force ,orificing and accumulator valve all provide biases to this equation.
Chris,
Could the 1-2 accumulator affect part throttle shift timing? Ever since I put a Gil Younger shift kit in the car the 1-2 part throttle shift occurs very early and does not respond to tv cable adjustment. WOT 1-2 is fine, I can hold 1-2 manual, and if I maintain speed below ~15 (in od or drive) the trans will stay in 1st. But if I accel in a normal part throttle mode the car shifts too early. Example, stopped then make a right hand turn, the 1-2 shifts before I am half way through the turn.
Mike
hey mike, this sounds like a governor problem. before going crazy, try installing another governor . also check tv limit valve and spring and tv-up valve and spring (some models dont use a spring) good luck, chris
