Adjustable Fuel regulator
Probably not...how do you plan on knowing if its adjusted right? I guess you could go to autozone and rent their gauge though...
you don't need a gauge mounted 24/7. get one from a rent a tool program or from a friend, set it to 43 line off and call it good. now if you having issues down the road we can address that later. basicly the regulator is a set it and forget it deal.
Be sure to check that the fuel pressure is raising under boost to prevent a lean condition/Knock.
agree, however if its set and he isnt having a problem i would hope he is getting a 1 to 1 raise. i never checked mine till i was having knock and lean issues after a new motor build. it was a blown seal in the turbo ;)
