luisturbog
UNDERDOG HOT AIR !!!!!!!
- Mar 30, 2007
Who sells a new wastegate actuator for hot air cars? Mine snapped at the base of the thread & I'd like to acquire a new one.
Like Pisano says, how do u eliminate boost solenoid & would I still be able to pass smog?Kirbans sells a new single hose one as well as a HD one. They work just fine. It will need another hole drilled in the bracket in order for it to sit lower and not hit the hoodliner. Brad
how do you make a single hose work on an originally double hose one
I disconnected my waste gate solinoid and all is good up to 20 ibs boost. I have no idea of the effect on smog because IL does not test or inspect any car older than 1994. Disconnecting the wastegate solinoid will require you to retune for no knock though. BradLike Pisano says, how do u eliminate boost solenoid & would I still be able to pass smog?
i dont want to sound stupid but what exactly is tuning the car
ive read it alot but dont know what they mean exactly
Yes- The single hose actuator works just fine. The bracket is different than the two hose actuator. If you use the stock mounting holes on the bracket when bolting to the turbo it will sit too high and hit the hoodliner. I simply drilled a new mounting bracket hole and have the actuator sit lower. I can send a PIC is you want. Bradi looked in the sticky and they mention it but you say if you go this route i can send you modified install instructions
O SO LO said:I have this one on my car- it is the 87 style the top hole is elongated (oval shape) to fit on to the turbo- the 84 replacement will come with directions to tell you which hose to cap off or eliminate...
http://www.kirbanperformance.com/product/196/ADJUSTABLE+WASTEGATE+ACTUATOR+#6696.html
