adjusting upper parameters with pro chip questions.
bpman1234
hi this maybe real easy but never did it soo .trying to adjust the upper parameters on my pro chip i dont have ac so i jumped the plug at the accumulator .the dumb question is the instructions say calpac out ? would that be the small chip inside the ecm? so there you go thanks in advance .
Yes, it's the small chip inside the ECM. You can temporarily unplug that, so you can get to the other parameters.
ok thanks eric.by the way the next thing i will get is the sd2 chip i must have read the instructions 3 or 4 times already so i can understand bit better .but i do know aint nothing better than hands on learning .thanks again.
