Aerospace Front Brake kit installed
jmendlik
Here is my new front brake kit installed. Its from Aerospace -their pro street kit w/slotted/drilled/plated rotors....The kit was $815 complete.
Also my new wheels-Billet Specialties Street Lite Race Wheels-
15X4 w 2-1/4BS. These wheels weight only 10Lbs!
JM
What size rotors are on the kit and are you running stock upper a-arms? Your combo of brakes and wheels looks sweet!
Rotor size
Rotors are 11" Diameter and I 'm running stock upper/lower control arms and still using the Powermaster. This kit was a simple bolt on all you have to do is cut the spindles and your god to go. It did change the offset on the front hub (moved it our 3/8") toward the outer fender.
JM
Sweet...
If the front rotors are 11", what size do u have in the rear?
The Aerospace kits run in odd rotor sizes, you most likely have the 10 3/4" rotor. Are your rims fitting without the 1/2" spacer?
Great kit, with the 2 piece, slotted and drilled rotors that's probably pretty light.
Rims/Rotors fittment
My front wheels fit no problems....I'm not using any spacer on the fronts....They made the front mounting bracket "reversable" so I would not have to run a spacer. My front wheel is 15x4 with 2-1/4 BS.
as far as the rotor size....Im running the Pro street front and rear kit. the rotor size is 11-3/4 .. check out their web site
PRO STREET KITS • AEROSPACE COMPONENTS, INC.
Joe
