After getting a couple of different sets of exterior door handles and installing them and not liking how they angled out so bad i decided to look into it a bit more. What i found was that the aftermarket studs sit up on more of an angle then a OEM one on the right side making it look like you have already opened up. So i notched the spring stopper in order to make it sit more like the OEM one. So if your doing door handles and you have aftermarket ones you might want to do this in order for them to look correct. The left side seems to look more like the OEM stud angle,so it might just be the passenger right one thats not made correctly. Just wanted to put this out there to help. I will know more tomorrow after i install them both, but this will fix them both if need be.
The one on the right is a new OEM chrome door handle to compare to. The final picture is of it complete with the notch done sitting flat.
