Air temp sensor thread size ?
434nova
Does anyone happen to know what the air temp sensor thread size is ? I am getting ready to tap my intake for the air temp sensor and need to know what size thread it is ? Thanks
No problem,
I put 2 extra 1/4 NPT holes in so I can move my vacuum lines as well. I put plugs in the holes for now. If you are thinking that you might move yours , this is the time to add them
Bryan
Can you guys post some pics of your modded intakes for the air temperature sensor?
Also, Phoneguy, what 2 vacuum lines are you referring to that need the 1/4 NPT in the intake?
The 2 1/4" NPT extras that I tapped is for moving my vacuum lines from the throttle body to clean up the look under the hood. I will run a T from both of the extra ports and connect all of my vacuum lines at the back of the intake. My car is in NC right now so I can not get a pic of the intake.
Bryan
