The angle of the light is the issue Brent. The numbers have more light so it causes them to fade out. You have a .5 separation on the caster, which is good, but the camber is screwed and will eat the tires. Camber should be closer to .1 pos to .1 neg. Your SAI and IA are good but it looks like your set back is a little odd.
