Alky compatable fuel injectors??
PhilM
Präzisionelektronik
I am working on my h2o setup that will use a DPSensor (analog output) and possibly swept and constant alky control via Motorola MAP sensor that will fire injectors at alternating pulses using a pluse width based circuit. This circuit will have absolute control over the injection and should offer excellent throttle response at any Boost level - no BOGGGGGGGGG.
I am trying to find some smaller (maybe 50# or so) fuel injectors for injecting alky to test my designs. Problem is most fuel injectors will prolly dry up if used constantly with alky. ANY suggestions?!
ANother alternative is to use an aquamist nozzle and get some sort of high Q solenoid but I havent been able to find a solenoid that will last in this type of set up - it going to have to fire many times per milisecond :eek:
