Alky Control Pump Head Pressure switch
aminga
Chicks Dig the powerbulge
Search is broken so pardon the repeat.
At what alky pressure switch does the switch close on Razor's alky pump assuming it's still set in it's factory default position. Put another way what alky pressure does the light on the controller turn from red to green.
Actually we set them to 50. But dependent on the spring pressure, temperature, etc. Since the pumps pulse at lower pressure, its more like a 45-55 psi range.
HTH
Thanks guys. I'm trying to track down a wiring fault
HTH
That helps too. I've seen the pulsing going on. When I was playing around at low boost. Included if anyone wants to see what it looks like
Why the spike so high in pressure when it activates?
Your not using my controller correct?
and whats with the fuel pressure
13 psi boost and only 49 psi fuel pressure???
I found it (the low pressure examining the log) Plus the base FP was a little low. I was trying to figure out why the ISAC was pulling boost.
