Alky kit green and tan wire ?
87SFI
Hi all, I have one of Julios older alky kits never installed and I'm stuck on step 7 under hood wiring to spiral green and tan wires but there is a plug to connect to something. I didn't see anything in the instructions where to plug this into? Where does it go?
Thanks!
Figured it out. Goes to the Alky tank low level connector. But the green wire has me stumped now. one end goes in the dash but where does the other end go by the low level connector? Where do I attach it too?
green is for the signal off the 3 bar map sensor (pin B) , other end goes to the PAC controller green wire ...without that wire the kit wont turn the pump on
