I've swapped out the 2 bar for the 3 bar sensor amd connected the factory plug. My factory boost gauge and analog dash is functioning. So, what wire am I suppossed to splice into the green wire on the plug?
Don't splice. Run a harness from the tps to the MAP sensor. It should be supplied if you bought from Julio. Be sure to run a dedicated line to the MAP sensor and zip tie it. Don't tee in any where on that line. If you want to retain the factory boost gauge leave the factory 2 bar sensor in place with its line and wires. You will just gave two MAP sensors
