Hello Everyone,
My alky kit has been working flawlessly since installed a couple months ago, but I went to start the car yesterday and it wouldn't crank and I noticed that pump won't stop running. The pump runs as soon as the key is turned to the ON position. I don't know if this has anything to do with it, but my instrument cluster was removed last week and was sent out for recalibration, so I am not sure if that could be the issue, since it was working before the cluster removal.
Additional info:
1. Pump wont run with map disconnected
2. Map signal is taken from behind glove per vortex Buick website. It gets the 5v signal from the map signal output wire under the dash .
3. Instrument cluster not in the car
Any ideas?
Additional info:
Any ideas?
