These can be activated through the use of a VCS(voltage switch) so lets say at anything above 25 PSI it kicks them on as additionals through a solenoid. So you run a set of dual M10's and when boost hits 25 PSI.. activate these..
Like I said.. things to think about.
Back under my rock
Hey i'm glad to see there is still someone thinking to refine it even more!
I do however would like to see a solenoid on a dual nozzle kit that the controller turn on and off depending on the boost! Cause a dual nozzle is way to much in lower boost settings for the street. VS high boost settings at the track . This would eliminate unhooking the second nozzle. Just let the controller turn on and off the second nozzle.
There is a few other things i would like to see money being no object like a flow meter in line to detect when a pump is getting weaker...or maybe a pressure switch that could alarm when the pressure don't metts a minimum pressure.
ok back under my rock.............
