The engine is demanding more fuel and boost. It's time to give it.
I'll be installing a 4 or 5 bar map sensor and will be upgrading the fuel system.
Presently, I'm running a single 2345-A Weldon pump with a voltage booster that is capable of increasing the voltage that drives the pump up to 50%. The engine has reached the limit of what this pump can supply being driven at over 16 volts.
I had no idea when I first put this engine configuration together that I would eventually be planning to push the output to over 1,200 Bhp. Originally, I thought I'd be very happy if the engine got me into the low tens, dreaming, maybe the high nines. Many people fought me on the idea that this configuration would be anywhere near successful. Well,... I have to call it, now. It's been an amazing success, and man, what an amazing ride it's been.
Now, it's time to push it beyond amazing success with the same out of the box thinking that got it this far.
Initial plans are to run the e-injectors off of the electric fuel pump and the mechanical nozzles off of a mechanical pump. The mechanical nozzles will be phased in as they always have been. The electronic and mechanical systems will be separate and will be free to use their own unique fuel supply pressure curves.
A second electric fuel pump will feed a surge fuel tank in the engine bay or in front of the radiator support. The size will be either 1 gallon or 1.5 gallons. The surge tank will feed the mechanical pump. The mech pump will be mounted where the evac pump is presently mounted and will be cog belt driven. The evac pump will be driven by cable. I haven't decided which accessory will drive the evac pump via cable.
Or, I may be switching to an electric evac pump, which would be the easiest solution for that. After all, I'm only using the evac pump to supply crankcase ventilation.
