Hi guy´s.
I have a Camaro 68 with a 200R4. It´s a transmission from a Monte Carlo 86, which I had locally rebuild here in Iceland. I used a heavy duty kit from Art Carr. After the rebuild it was perfect in almost any way, except that when I pick or step on the gas so that the transmission changes down from third gear to the second, it immediately responses and shifts down, but for two or three seconds it does not find the second gear and revs dramatically and then comes in with the second gear with a considerable slip and most often it ends up spinning the wheels franticly which in some cases can be quite dangerous. However, when this happens and I go off the gas and on it a gain, it goes immediately into the second gear. The TV cable is correctly adjusted and the fluid level is right. It is almost ok when cold, but as soon as it heats up (5 min) it starts doing this. I have already had the valve body rebuild, but no change. The builder thought it was the valve body, but the problem is still there. I don't know if there is any connections, but when it is hot, it always goes into Drive with a considerable clonk. I am a bit lost and no one seems to have a clue what is happening here. If there is anyone out there who recognizes this problem, I would be so grateful if you could help me.
Hope to hear from some genius soon.
Skuli K. Iceland.
Skuli K. Iceland.
